Is this the right pin to wire the MSD window switch
Old Jan 9, 2005 | 10:14 AM
91RSLT1's Avatar
The motor is a 95 and from looking at the wiring diagram I need to tie into the red connector pin A13 tach output (white) and tie it into the window switch's white wire. Is this correct? I also have a MSD dig. 6 and was wondering if it has a tach output I can tie into instead of using the pin out of the PCM (I can't find my owners manual). Thanks
Old Jan 10, 2005 | 10:52 PM
92LT1RS's Avatar
Re: Is this the right pin to wire the MSD window switch
My MSD 6AL has a tach output, I'm sure the 6 Digital does too.
Old Jan 11, 2005 | 10:55 AM
91RSLT1's Avatar
Thanks I just found my manual and the dig 6 does have a tach out put so I will just use that.
mr28
Apr 20, 2016 05:44 PM
mattstrike
Mar 11, 2015 07:33 PM
mr28
Nov 23, 2014 11:11 AM
Red97LT1
Aug 15, 2002 08:33 AM
