how do you adjust throttle cable?
Old Dec 30, 2004 | 08:50 PM
klpps's Avatar
need advice on how to adjust the throttle cable after I install my wet plate which did not come w/ adapters. any help would be appreciated. thanks!
Old Dec 30, 2004 | 10:53 PM
95_LT1_6SPD's Avatar
Re: how do you adjust throttle cable?
can you get it where you need it by backing off the idle screw?
Old Dec 30, 2004 | 11:27 PM
Mr_Bond's Avatar
If your using a plate, you need to get the linkage bracket adaptor for the company that makes the plate. The adaptor will put the cable bracket where it need to be. It is to far off even if you try to use the cable linkage adjuster.
Old Dec 31, 2004 | 12:07 AM
klpps's Avatar
ive heard of some people being able to use the plate w/out any adapters. anyone on the board done this?
Old Dec 31, 2004 | 08:38 AM
RacinLT1's Avatar
you cant adjust it properly without the adaptors. some guys may have gotten close,but why risk a compromise? what plate is it?
Old Dec 31, 2004 | 10:17 AM
klpps's Avatar
i believe its a nos plate. its black and the fuel/nitrous lines go in through the side.
Fastbird93
Apr 9, 2016 07:01 PM
jimmybandana
May 11, 2015 11:41 AM
edman
Jan 25, 2015 02:41 PM
DETROIT_AREA_00_SS
Aug 12, 2002 11:32 AM
