Quick question for Vortech owners please...
Old Dec 19, 2004 | 11:23 PM
roguedriver's Avatar
So just about done with my S-trim install and noticed that it says to run a line from the charger intake (right after the MAF) to your breather. Should I do this or just leave the stock breather setup and plug the air intake hole? What will happen if I don't run a breather line like Vortech suggests? Thanks.
Ken R.
Old Dec 20, 2004 | 06:26 AM
john35thss's Avatar
Re: Quick question for Vortech owners please...
Higher crankcase pressures and lots of oil leaks.
Hook it up
John
Old Dec 20, 2004 | 09:58 AM
Thats what I was thinking also but just wanted a second opinion. Thanks John.
Ken R. 95Z
Old Dec 20, 2004 | 07:34 PM
OBE1 95Z28's Avatar
The line that mounts in the valve cover is the air source to "feed" the PCV. Metered air (air after the MAF) is used as this air will be dumped back into the intake manifold to be burned. Vortech extracts the air before the blower so that it will not be pressurized; it lets the PCV suck in the air that it needs.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
onefastgta
Mar 19, 2015 10:10 AM
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
