New Engine
Old Dec 19, 2004 | 09:52 AM
[B]attery's Avatar
New Engine
i prolly should have searched this...but i'm rather busy today...but i have a 95 maro with a 3.4L v6...my mom being the idiot she is ran the engine for 30k miles without changing the oil and its about to throw a rod...well we've salvaged the engine but it isn't going to last very long...so i'm wandering if i can jsut drop in a 3.8L v6...if so...which year...do i need bigger injectors? what about anything else? can i use the same chip?
Old Dec 19, 2004 | 10:55 AM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
Re: New Engine
no you cant just "drop it in"
you doomed your post when you said you didnt search, but no, you cant jsut drop it in, do a search
welcome to the board
Old Dec 19, 2004 | 12:56 PM
camaro 22's Avatar
Re: New Engine
If you're going to put a new engine in, you might as well put an LT1 in there. I put an LT1 into my car. Probably wouldn't be much more than just putting another V6 in there.
Old Dec 19, 2004 | 03:32 PM
[B]attery's Avatar
Re: New Engine
an lt1 would need a new tranny...new radiator...new injectors...new a lot more stuff....if i can jsut get a 3.8 and drop it in...with only having to buy a few things...then it'd be alot cheaper then a lt1...also if i was going to put an lt1 in there...i'd put a 400...well because my dad has a block and heads for one already...
Old Dec 19, 2004 | 04:09 PM
95wannabe's Avatar
Re: New Engine
I've got a 3.4 for sale, cheap, if your interested. Where are you located?
Old Dec 19, 2004 | 11:19 PM
ChevyTuffD.A.'s Avatar
Re: New Engine
Youd never be able to fit a conventional distributor type engine such as that 400 into an f-body, the trouble would not be worth it. But u can go to a salvage yard or look on the boards and buy a complete motor with everything including accessories for as cheap as $1200 or so. As far as tranny i dont see why u couldnt just use your old 4l60E, thats what u have right?? I may be wrong but u should be able to use it. If u decided to do it and completed it you would be so glad u did trust me.
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
