BMR K member install need HELP!
I am installing my bmr k member on my 94 z28, I already sorta tigten the 4 main bolts and I noticed where the rear of the k member where it blots on the frame rail, there is a 1/4 inch gap and basically to get it flush with the frame rail it may have to bend. Should I try bolting the rear first, then the 4 main one to get this thing lined up better???
Btw the 6 bolts to the k member, is there any torque specs on these??
Thanks, Mark
Thanks, Mark
Re: BMR K member install need HELP!
The one I have mounted right up. I'm sure there is no problems with having to pull the parts together. 1/4 inch isn't much at all. Could be due to your frame or the parts when they were made. Needless to say, I wouldn't loose sleep from it. BMR makes great parts.
loosen the other 4 up a lil and see if u can get the other 2 in tighten them after all of them are started. im shure that it has a lil bit of play in it to be moved
