Stumble under slight load
Old Dec 14, 2004 | 09:52 PM
Red on Red WS6's Avatar
Question Stumble under slight load
OK let me start off by saying this problem is a friend of mine. He has a 96 V6 Camaro and there is a pretty good stumble & constant missfire above 3000 RPM.
He had it scanned and they said it was a missfire on #6 cylinder, I told him to replace the plugs and wires, and he said it did not fix the problem. So then I told him to replace the coil pack. problem still there, I told him I will test the fuel pressure tomorrow. So my question is what pressure should I see and is there anything else I should check? Thanks
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
