Fuel leak, wont start
Old Dec 11, 2004 | 01:35 PM
deepstage69's Avatar
OK its a 95 v6, its had hard starting for a while, Then it would get to where it wouldnt even start, we took it to have the injectors cleaned on a machine that screws into the valve on the fuel rail, that would cure it, for about a month or little longer, but today it started doing the same thing, so i checked fuel pressure, and turned key on, immediatly jumps to a little over 40 and as soon as the pump turns off, pressure starts dropping, and within a minute its at 0 pressure. I pulled the fuel rail loose, to check if it was leaking didnt visually see anything. could it be bad pump?
Any info is greatly appreciated.
Kevin
Old Dec 21, 2004 | 07:00 AM
viper03af's Avatar
Re: Fuel leak, wont start
rplace your fuel presure regulator, and make sure vacum lines ar on it too.... it the weird looking thing on your fule rail on the drive side
Old Dec 21, 2004 | 11:45 AM
Tiago's Avatar
after the pump primes pressure will drop, thats normal.
but when you turn the key it should start priming again and keep pressure high.
Old Dec 21, 2004 | 01:43 PM
viper03af's Avatar
mine dont drop at all even after 5 minutes like maybe 1 psi if at all
Old Dec 22, 2004 | 08:40 AM
camaros_4_lfe's Avatar
mine usually take about 5-10 to drop to zero
dunno how long it should take on a stock regulator
Alex Barnes
Jan 24, 2015 10:21 PM
Jessie4tin
Jan 7, 2015 08:53 AM
blac94Z
Nov 28, 2014 01:53 PM
blac94Z
Nov 24, 2014 07:12 PM
