Spark plugs have a thinn white coating on them......whats that mean?
Old Dec 3, 2004 | 10:21 PM
JaxCamaroGuy's Avatar
i just bought my 96 black camaro 5spd v6, has 110K miles, i took some spark plugs out to inspect them, they all have a thin white coating on them, whats that mean, fuel too lean?
Old Dec 5, 2004 | 02:34 PM
95LT1Z28's Avatar
Re: Spark plugs have a thinn white coating on them......whats that mean?
Means it is running on the lean side a little. As long as the engine is not making any noises I wouldn't worry about. Although, it wouldn't hurt to change the O2 sensors if they are original.
Jeff
Old Dec 5, 2004 | 05:38 PM
oneledvr's Avatar
Lean!
Old Dec 5, 2004 | 09:06 PM
Yes, they are orginal, umm think i should go ahead and replace the plugs?, and btw my gas mileage is kinda sucking, think o2 sensors could attribute to that since its running lean?
Old Dec 5, 2004 | 09:36 PM
95LT1Z28's Avatar
I would do a nice tune-up on the car. Change the plugs, wires, PCV valve, fuel filter, oil/filter, O2 sensors, etc. This will let you know that your car is running up to its full performance. The poor gas mileage could be attributed to bad O2 sensors, but could be other factors also. That is why I recommend a nice tune-up for your f-body.
Jeff
Old Dec 6, 2004 | 10:18 PM
Bud M's Avatar
Original plugs at 110k? Replace 'em. I'd do O2s too, and your cat is probably on its last legs too, which can contribute to bad mileage.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
