Oil Leak - Can I stop the smell from inside the car?
Old Dec 2, 2004 | 12:55 AM
RansZ28's Avatar
Question Oil Leak - Can I stop the smell from inside the car?
So I have a small leak. When it does it hits the exhaust and I can smell it inside the car. Anything that I can do to coat the exhaust or???
Old Dec 2, 2004 | 01:34 AM
IRONFIST's Avatar
Re: Oil Leak - Can I stop the smell from inside the car?
Probably not dude... you'll just have to fix the leak, or some how rig your exhaust so that the leak doesn't hit it.
Old Dec 2, 2004 | 09:43 AM
RedHottG2's Avatar
Easiest way around your prob is to just fix the leak.
Old Dec 2, 2004 | 03:44 PM
TraceZ's Avatar
Here is another vote for fixing the leak.
Why is this even a question?
Old Dec 2, 2004 | 05:32 PM
RansZ28's Avatar
I used the die and just cant find the leak. Whats it to you?
Old Dec 2, 2004 | 05:43 PM
TraceZ's Avatar
Well, geez you didnt say you couldnt find it. You made it sound like you were too lazy to try and fix it and wanted a "rig".
Start by narrowing it down to a lower leak or a upper leak. The intake manifold commonly leaks at the rear edge where it meets the block. Take a towel and wipe back there, see if it is wet. It is not tooooo hard to replace the intake manifold gaskets. The valve cover gaskets are cheap and easy to replace if they are the culprit.
Lower motor leaks like the oil pan and timing cover usually dont get on the exhaust, they just drip on the ground.
Good luck.
Old Dec 3, 2004 | 12:19 PM
Z28SORR's Avatar
Here's a clue, where will be a wet oily substance near the leak.
Have we been having a hard day?
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
USAirman93
Nov 24, 2014 03:37 PM
NAVY99
Oct 3, 2002 03:47 PM
Brian-94TA
Jul 31, 2002 02:52 PM
