94 / 95 4L60E compatibility
Old Nov 26, 2004 | 08:11 PM
a walker's Avatar
I have a 94 Z28, and I need to pull my trans out for a repair. While the trans is getting repaired, I have a 4L60E from a 95 Z28 that I am going to put back into the car so it is driveable. Question is, are they compatible? I know it will bolt up and everything, but what about the electronics?
Old Nov 27, 2004 | 06:20 PM
a walker's Avatar
Re: 94 / 95 4L60E compatibility
Somebody has to know...
Old Nov 28, 2004 | 04:56 PM
a walker's Avatar
TTT, I want to get this in this week if it will work.
Old Nov 28, 2004 | 06:00 PM
Lonnie Pavtis's Avatar
Although I am not a tranny expert, I will try to help you. If I'm in error at least I tried.
To the best of my Knowledge, the '95 up trannys used a pulse width modulated lockup & the '94 used basic on/off lockup control.
I believe the '94 trans will not work properly with the PWM lockup of the '95 computer, but I believe the opposite ('95 trans in a '94) will work OK.
At least this is something to base your research off of.
Old Nov 29, 2004 | 08:38 PM
a walker's Avatar
Thanks for the info. Looks like I'm going to swap my trans out tomorrow
Old Nov 30, 2004 | 03:36 PM
kostya_f's Avatar
My friend's 95 had a 94 4l60e in it and it kept setting off tcc lockup solenoid code, but worked fine otherwise.
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
