NO throttle at all, Just idles
Old Nov 25, 2004 | 07:53 PM
rodshop454's Avatar
Arrow NO throttle at all, Just idles
I bought this 2002 Camaro convertible as a "builder".
Easy hit in the front right corner. It's a 6 cylinder.
The car runs just fine but when you push on the gas peddle it doesn't do anything.
Is the throttle on these electronic?
Any help appreciated!
Old Nov 25, 2004 | 09:33 PM
mike996's Avatar
Re: NO throttle at all, Just idles
Yup they have throttle by wire. I don't know much about that but from how it sounds you're screwed.
Old Nov 25, 2004 | 10:20 PM
HBHRacing's Avatar
There are 2 TPS sensors in the motor unit. there is an APP sensor on the gas pedal. Start by looking at that and the throttle body to make sure that theya re both pluged in and working. Then check the fuses. I don't have the wireing diagram for the system with me so thats all I can tell you for now.
Old Nov 26, 2004 | 05:41 PM
rodshop454's Avatar
Thanks for the info!
I know ALL is fixable just needed your guys knowledge to find it!
Thanks again!
andrewcapps82
May 19, 2015 10:11 PM
lt1matt
Mar 21, 2015 07:35 PM
edman
Jan 25, 2015 02:41 PM
edman
Jan 22, 2015 02:45 PM
David Dorris
Jan 17, 2015 08:10 PM
