Monsoon amp?
Old Nov 24, 2004 | 03:05 PM
Rifleman_btx's Avatar
Monsoon amp?
I was wondering if it was a true amp or just some sort of cheap crossover, becuase I heard a BIG difference in the sound when I swaped head units to my Alpine. If it is a true amp, why does it sound louder now? The only thing I can think of is cleaner output reproduction.
Old Nov 24, 2004 | 03:23 PM
Re: Monsoon amp?
I'm also looking for a good 4 channel amp as well. If anyone can help me out with that, that would be great!
Old Nov 24, 2004 | 05:05 PM
96m6lt1's Avatar
Re: Monsoon amp?
you will have that,the factory deck only puts out a minimal amout of power an aftermarket deck will put double the power or more........
Old Nov 25, 2004 | 08:33 AM
LS1 RULZ's Avatar
Re: Monsoon amp?
The POS Monsoon amp is not a true power amp. It's a distortion producing power booster that only has speaker level inputs.
Old Nov 26, 2004 | 01:20 AM
Re: Monsoon amp?
Yeah, its just an overpriced option that has to come out anyways, becuase it sucks. I figured as much...
Old Nov 26, 2004 | 01:41 AM
Re: Monsoon amp?
I want to know what would be the best idea to running a new amp setup, I have a Sub amp running off one set(rear) preamp jacks. I also have a 2 channel amp I want to run for the rear deck speakers. I also want to run the third amp a 4 channel to the front and middle speaker sections. I know I can most likely use a line amp converter for the rear middle, but would it be wise to use a Y conector for the rear channels? I fear a small lose of signal or a possible noise conduction. That is the only reason that the reardeck is still hooked to the POS Monsoon amp. They are Infinity 4X6 plate units with seaprate tweeter and 4" woofer (these made a heck of a difference over the dual cone crappers that was in there). My subs run off a 100X2 amp and I want to run 50X2 to those Infinities and 50X4 to the front/middle (when I get two sets of 6 1/2" to replace those factory junkers.) My thinking is to use the Y for my back speakers and sub. use the converter for the middle, and the front preamp from the Alpine to run the door speakers. Any thoughts to this?
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
Brian-94TA
Jul 31, 2002 02:52 PM
