chromoly pushrods
Old Nov 23, 2004 | 11:27 PM
Michael Ozorowsky's Avatar
chromoly pushrods
what is point? THese are stronger than stock right? Are these the same as forged? Thanks.
Old Nov 24, 2004 | 12:07 AM
WiseguyZ28's Avatar
Re: chromoly pushrods
u just helped me in my thread and now i'm helpin u back. I was just at LS1tech for a little while and posted in this about 15 minutes ago, read this one http://www.ls1tech.com/forums/showthread.php?t=242103
I planned on going with the best/strongest parts but maybe thats not a very good idea, we'll see what other input anybody can give us though.
Old Nov 24, 2004 | 12:11 AM
yeah, I'm going to go with stronger pushrods, just not sure if chromoly is the same as forged. Thank you for post I will keep an eye on it.
Old Nov 24, 2004 | 04:39 AM
AL SS590 M6's Avatar
No such thing as forged pushrods. There's steel and CM steel. One piece or modular.
Hardened steel or CM one piece is the way to go. You MUST get rid of the stockers when going to stronger springs and a cam.
Old Nov 24, 2004 | 08:45 AM
Thank you for cleaing that up for me al.
Old Nov 24, 2004 | 01:20 PM
Ferocity02's Avatar
Actually you do not need to go to aftermarket rods when you change the cam or springs. Most people just to do it for reliability in the event of a miss-shift and to reduce valvetrain weight(with chrome-moly).
Old Nov 24, 2004 | 04:08 PM
Another stupid question here, what do you gain by reducing valvetrain weight?
Old Nov 24, 2004 | 08:12 PM
Ferocity02's Avatar
Power!!! Not much, probably not even a dyno gain, but it's there. The reliability and added strenght is really the point of aftermarket rods.
Old Nov 25, 2004 | 03:30 AM
I totally disagree. There's no way that I'm going to run my .615 lift cam with double springs up to 7000 rpm with pushrods that bend as easily as the stockers do.
Old Nov 25, 2004 | 01:26 PM
Ferocity02's Avatar
Stock rods don't bend because of big cams.... They bend because of misshifts and bad P/V clearence. I know of many people that still are running stock rods simply because they arent needed, nonetheless most get them anyways.
Old Nov 25, 2004 | 04:07 PM
I'll get them but how safe do you think it is to buy used? Someone is selling the for $30.00
Old Nov 25, 2004 | 05:55 PM
chpmnsws6's Avatar
quicker to spin the motor, and more than that.. ALOT less valvetrain noise since ours sound like sewing machines
Old Nov 25, 2004 | 07:05 PM
OMG that is funny. Actually yah does sound like a sewing machine.
Old Nov 25, 2004 | 07:51 PM
Ferocity02's Avatar
I'd be very careful buying used ones. Ask the person to roll them on a flat table. This is the best test to see if they are bent. Other than that, buying them used is fine, they don't really wear down.
Old Nov 26, 2004 | 06:29 PM
Thank you. Appreciate the advice everyone. Thanks again.
13qtr
Oct 28, 2016 08:11 PM
Nutty's96
Dec 21, 2015 06:25 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
karpetcm
Sep 29, 2015 10:08 AM
Slayer
Aug 17, 2015 03:55 PM
