Soon to do heads/cam is this worth it?
Old Nov 23, 2004 | 11:10 PM
Michael Ozorowsky's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...category=33625
Is this any good? I am dumb here, but I heard I have to or at least I should replace my timing chain while I've got my motor torn down. Is this part good? Or should I replace timing chain? What all needs to be replaced with heads/cam swap? Thanks.
Old Nov 23, 2004 | 11:17 PM
mavricki18's Avatar
Re: Soon to do heads/cam is this worth it?
www.ls1howto.com Has step by step instructions and every thing you need to know to do a heads/cam swap
Old Nov 23, 2004 | 11:29 PM
yes Mavrick, that is the site I am using, and it says to replace timing chain, but do I need the double roller? I am looking for strength, but what are downsides? Is there something I am going to ahve to modify in my motor to make a double roller work? Is there anything I should know or is this a direct replacement? And again, I SHOULD replace my timing chain while I have motor apart right? I'm just trying to do this right.
Old Nov 23, 2004 | 11:44 PM
V6toZ28's Avatar
Depends on how many miles you have. If you have less than 50K I wouldn't bother ... between 50-70K tossup ... more than 70K go ahead and make the change. But on just a routine NA H/C set up, putting in a new stock chain should be fine.
Old Nov 24, 2004 | 12:22 AM
I'm at 62K miles now. So I take it I should replace chain, but do I replace with double roller or regular?
Old Nov 24, 2004 | 04:35 AM
AL SS590 M6's Avatar
Just a single. I'm running a high strength single chain with the origional gears.
Old Nov 24, 2004 | 08:50 AM
Thank you again, AL, LOL.
Devinfoote87
Feb 12, 2016 03:21 PM
blaze309
Sep 8, 2015 05:27 PM
colts0455
Sep 2, 2015 12:41 PM
mark0006
Aug 29, 2015 09:45 AM
whitehooptie
Aug 17, 2015 08:35 AM
