header install problems
Old Nov 22, 2004 | 07:17 PM
camaroz99b's Avatar
alright i started putting in my lt headers today. i raised my car to the highest my jackstands would go wich is like 22 in. I am at the part where u install the new header and i dont have enough ground cleareance to put the header in from the bottom plus it seems to want to rub against the oil filter. basically im just seeing how u guys did it if u didnt have a lift. thanx
Old Nov 22, 2004 | 09:17 PM
Fear The Z's Avatar
Re: header install problems
Maybe your not holding your mouth right- we installed mine on jack stands witn no problem.
We also removed the oil filter.
Old Nov 22, 2004 | 11:42 PM
BirchMan98z's Avatar
I installed my SLP headers on jackstands and ramps, and had no problems, and they're larger than most.
Old Nov 23, 2004 | 07:39 PM
camaroz99b's Avatar
well i have run into another snag... on the passenger side how do you get the exhaust manifold rearmost bolt off??? ive read to do it under neath the car but there isnt room there either.... im only 16 so i dont have much expierence...
Old Nov 23, 2004 | 07:56 PM
camaro-chris-ss's Avatar
do you have the rear jacked up too ?
Old Nov 23, 2004 | 08:53 PM
Fear The Z's Avatar
I had the starter off when I did my hooker headers...may want to take yours off and see what you can do then about that back bolt.
Old Nov 24, 2004 | 03:23 AM
lol someone doesn't have the right tools. My 5" teensy ratchet/socket got in there just fine. found the bolt with my fingers, and just felt around until I got it from the top.
Noenav
Mar 1, 2019 07:38 AM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
