How does one test an "R" lifter
Old Nov 14, 2004 | 01:30 PM
SABLT194's Avatar
I have a lifter making a ton of noise so I lashed it down tighter to see if it would go away. No dice. Makes noise both hot & cold. So, I yanked the lifter and it looks ok -Visually that is. What's the proper procedure for checking the hydraulics of the lifter.
Thanks
Steve
Old Nov 15, 2004 | 12:18 PM
Fastbird93's Avatar
Re: How does one test an "R" lifter
I had a similar issue with my Comp R's and while I never found an official test, I tried this and it may or may not help you.
I just pushed on the rocker directly above the pushrod to see if I could compress the lifter. When my motor was cold, it wouldn't compress at all. But when the motor was warm, it took almost no effort to completely compress the lifter. Bad juju there.
Old Nov 16, 2004 | 07:06 AM
Hot Rod Hawk's Avatar
I did it by calling Comp Cams and getting a return Auth Number for my [R's]. Just tell um you need them Inspected and Rebuilt if needed.
I recieved a nice new set a week later at N/C
97SSdude
Aug 21, 2015 09:36 AM
realistyc
Jul 28, 2015 07:32 PM
alphaauto
Jul 26, 2015 04:40 PM
94Form
Jul 17, 2015 10:56 PM
