What MM back spacing???
Old Nov 11, 2004 | 09:15 PM
LPE_wannabe's Avatar
what MM back spacing do i need for 18x9.5??? i searched for it but couldn't find it...thanks
Old Nov 12, 2004 | 12:55 PM
LPEdave's Avatar
Re: What MM back spacing???
Usually backspacing is measured in inches, maybe that's why you're not finding it. A 9.5" wheel on a 4th gen needs about 7" of backspace, that would be 178mm.
Dave
Old Nov 12, 2004 | 04:54 PM
well the wheels i want (C6R's) 18x9.5 + 56mm so i was assuming that was the back-spacing...guess i'll just call em when i'm ready to buy
Old Nov 12, 2004 | 05:46 PM
In the wheel you mentioned, 56mm is the "offset"... the distance the mounting face is moved out ward from the centerline of the wheel. That is the correct offset for a 9.5" wide wheel on a 4th Gen. Anything from about 45mm to 56mm will work. The 56mm offset will give you a backspace of about 7.4 - 7.5".
Old Nov 15, 2004 | 12:16 PM
Originally Posted by Injuneer
In the wheel you mentioned, 56mm is the "offset"... the distance the mounting face is moved ******d from the centerline of the wheel. That is the correct offset for a 9.5" wide wheel on a 4th Gen. Anything from about 45mm to 56mm will work. The 56mm offset will give you a backspace of about 7.4 - 7.5".
ohhhhhhh...that makes more sense...thanks!!!
alex5366
Mar 8, 2015 11:32 AM
WildRidez
Jan 16, 2015 03:10 PM
Jan 13, 2015 09:52 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
Snoman73
Nov 17, 2014 07:22 PM
