question with abs removal
Old Nov 3, 2004 | 03:07 PM
tonylittell's Avatar
ok when i remove the big abs box with the lines and plugs going to it will i set a light off?
what do i do with the clips that pluged into the abs box?
any input would be appriciated
thanks
tony
Old Nov 4, 2004 | 10:58 PM
Z95m6's Avatar
Re: question with abs removal
Is there any reason you are removing the ABS system? i don't really see a reason to do so.
Old Nov 6, 2004 | 06:44 PM
there are several reasons i removed it (and many others in here)
1 weight reasons...it is a car i will only use at the track
2 making room under the hood and cleaning under there up
3 its fugly and im an experianced driver...dont really need abs
Old Nov 6, 2004 | 07:13 PM
Bone Daddy's Avatar
you wont need the box.. just clip and clean up the junk, after re-routing the pipes.
Old Nov 7, 2004 | 06:08 PM
yea i know i wont need the box...im just wondering it a light will come on ...i cant find out as my motor and kmember are sitting on my front porch! lol
also all the plug in clips that go into the abs box do i just tuck them away somewhere or what?
thanks alot
tony
Old Nov 7, 2004 | 11:57 PM
Bone Daddy's Avatar
Yes, you will get a light. (why wouldn't you?) You will need to remove the abs bulb behind the dash, or have it edited out of your ECU. As for the plugs.. hide them or snip them as I stated above. Just make sure if you do, that no bare wire is present.
Old Nov 9, 2004 | 06:53 PM
i have to send my ecu back out for tuning so i may have it edited out then...i asumed it would send the light ...but wanted to make sure...and like i said with the engine sitting on my front porch i couldnt check and verify
thanks alot for the reply
tony
sscott
Jan 17, 2015 04:30 PM
squarehead
Jan 15, 2015 07:02 PM
cmdeshon
Dec 27, 2014 10:06 AM
pologreen97z
Dec 2, 2014 10:42 AM
97TA-WS6-Con
Sep 5, 2002 02:26 AM
