What do I need done to handle 15 pounds of boost??
Old Oct 31, 2004 | 09:06 PM
detroit1994z28's Avatar
What internal modifcations do I need done to handle 15 pounds of boost on my daily driver. I'm trying to save any money I can. So parts I can get away with - that will work out great. Like I know someone running 10 pounds and using the stock crank - So any little help will be great
Old Nov 1, 2004 | 10:58 AM
rskrause's Avatar
Re: What do I need done to handle 15 pounds of boost??
15psi is a lot for an LT1 on pump gas. The primary thing you will need to do is lower your CR to the 8-8.5:1 range with the use of a good set of forged pistons. An upgraded set of rods is also in order. The stock crank may be sufficient, the main problem there may be failure of the crank snout due to the stress of the blower belt. So, it should probably be replaced as well. IOW, you need a new rotating assy.
Rich
Old Nov 1, 2004 | 11:29 AM
Pro Stock John's Avatar
You need an upgraded fuel system and I would run 8-8.5:1 compression. You also need decent intercooling to run a decent amount of timing to make some power. 15psi on a 355ci LT1 sounds decent but if you can only run low timing advance a person with 12 psi and better 'cooling might make the same power.
Old Nov 1, 2004 | 09:44 PM
sleeperz28's Avatar
15lbs of boost with what? A small supercharger, thumper turbo, large supercharger, small turbo? All depends on what blower your running. From there we can start recommendations
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
NewsBot
Sep 14, 2015 09:20 AM
NewsBot
Sep 14, 2015 08:50 AM
tommalcolm
Sep 11, 2015 03:39 PM
