how long to pull a trans of a 94Z?
Old Oct 28, 2004 | 08:04 AM
94Zpower's Avatar
My trans blew yesterday and I m gonna pull it out this weekend I have pulled and re installed a trans on a 88 Mustang with out a problem so I am capable but our cars everything seems to take longer so how long do you think it should take??
Thanks!
Old Oct 28, 2004 | 11:35 AM
97FormulaWS-6's Avatar
Re: how long to pull a trans of a 94Z?
Depends on how well you know your car, there are a LOT of variables that can effect how long it takes... for most people 1-4 hours...
Some of us who have done it a few too many times can do a full swap in under an hour.
Old Oct 28, 2004 | 12:55 PM
1SlowFormula's Avatar
With out ever pulling a trans before, and stopping to go grab the right size sockets and that sort of thing I pulled mine in about 3.5 hours. I reinstalled it in less, once you get it up high enough and you get onder there you will see what is needed to do it. I first thoughthat I didn't need to, but dropping the Y-pipe will make it easier, I took mine most of the way out then found if I dropped the Y-pipe sooner I would have already been done! Trying to work around the Y-pipe and the fact that it won't allow the trans to drop down as far, to get to the top bolts probably added about an hour to my removal. I followed a lot of this write up even though it was for a converter swap, they still droped the trans. http://www.zmydust.com/converter.html
Old Oct 28, 2004 | 01:36 PM
Loadre's Avatar
I'll say 2-3 hours.
Us pros can take them out and stick it back in almost exactly an hour.
Old Oct 28, 2004 | 06:12 PM
12SCNDZ's Avatar
From the time the car was pulled in the garage until the trans was on my bench...20 minutes. OK, so that was from a professional installer . To be realistic, though...These transmissions are pretty easy to get out. I'd say 1.5-2 hours for a "rookie".
Frank
CPT
Old Oct 28, 2004 | 09:55 PM
revtime's Avatar
I pulled mine out by myself and it took about 3 hours, I wasn,t rushing.
Had a friend help me install it and it took about 30 minutes.
Old Nov 1, 2004 | 02:02 AM
Meen95z's Avatar
Im on a basis now of doing it, its about 3 hours if its your first time, 1 or so if you done it 2 or more times.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jan 5, 2015 07:14 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
