How much boost can a deltagate actually control?
Old Oct 26, 2004 | 09:58 PM
Timberwolf's Avatar
I have a deltagate I got with the car. Has a number 9 spring in it. The turbo I am using now is a PT61. I figure on running somewhere between 22 and 28psi depending on the mood I am in that day, the tune, fuel, etc.
Can a deltagate control that much boost? What about the stock swing gate? Can you run both?
If this deltagate won't handle the boost I'll sell it and be on the lookout for what will, so any recommendations are welcome.
Old Oct 28, 2004 | 08:20 AM
Z28tt's Avatar
Re: How much boost can a deltagate actually control?
What do you mean by "handle"? Are you thinking it will open before you hit your boost numbers, because the exhaust backpressure is so high? Or are you thinking it won't flow enough to prevent overboost?
Andris
Z28tt, w/ two deltagates...
Old Oct 28, 2004 | 10:44 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
a small gate has trouble handling LOW boost, not high. It totally depends on your exhaust back pressure to intake pressure ratio as to how much max boost you can handle.
Mar 13, 2016 03:37 PM
Formula Steve
Sep 19, 2015 08:48 PM
Henson071
Sep 18, 2015 04:01 PM
Aug 7, 2015 01:26 PM
Henson071
Aug 4, 2015 09:32 AM
