What the @)$(&%# is wrong with my M6 ? HELP ASAP!
Old Oct 25, 2004 | 09:24 PM
HardcoreRM125's Avatar
I drove out to Philly this weekend to visit my girlfriend, who is going to college there for the semester. Its like a 300 mile trip there, 300 miles back. Car ran PERFECT there, not a flaw. Parked it in the parking garage for the weekend.
On the way home. About 150 miles into my way home, im in 6th gear doing about 80ish? All of the sudden I hear this terrible noise coming from the transmission area. It almost sounded like someone was dropping a fist full of nuts and bolts into a empty pan, while dragging it on concrete. I know its a weird description, but thats the best way to explain. Now my car, ONCE before, threw a hissy fit and wouldnt go into 6th gear, so I thought maybe its just the gear. Go to throw her down into 5th, and the shifter wouldnt go past the nuetral area. As this is happened, it was making that "Grinding" noise it makes when someone new at driving a s stick is pushing it into gear without the clutch in. However, I had the pedal TO THE FLOOR. So I moved the shifter left and right, to assure im in nuetral, while it was still making this sound, I slowly let the clutch out and the moise goes away. However, when I tried putting it into 5th, then I let the clutch out, it shot the shifter back down and kicked it out of gear. So then I pulled over, glanced over the car, and got back in it. It was ok going through 1-4th, then it didnt want to go into 5th. I got it back into 6th gear.
So now here I am on the Turnpike, 6th gear tryin to keep up with traffic. Every time I would have to decelerate ( Note: NOT braking, just not accelerating, as in letting off the throttle) The car would make some type of faint "metal tumbling" noises in the tranny. Id give it gas, it would fade away. However, every time I gave it gas, if I wasnt SUPER easy coming into it, it would make some weird *** noises too. So then 6th gear started to get even noisier. I tried to downshift it into 5th, and it was like I didnt have the clutch in, it started grinding and shot it into the Nuetral spot. However, The clutch was to the floor, and the clutch IS fine. It is not the clutch.
Now I'm almost home, about 20 more miles away, and I start getting into more residential areas where you are using 1-4th only. I shift it into first to pull forawrd to a toll-booth. As I shift it in ( From a stop ) it was fine, I roll forward, push the clutch in, and am braking, but the shifter is still in gear. It continues to make this terrible noise like someone is forcing up on the hsifter, trying to put it into a gear without the clutch in. However the clutch WAS in, and the clutch seems to function fine?
Now the only way that it is ALMOST normal shifting ( As in wont make noises and pop right back into nuetral, sound retarded and making loud noises like grinding, or droping nuts and bolts ) is if I double clutch it. Like Start out in first, shift to Nuetral, let clutch out, back in, shift into 2nd. clutch out, and hope it doesnt make noises and **** up. What the hell can cause this? And as soon as I start to decellerate, it goes right back to making slight, but bad noises, like metal scraping metal or something.
My transmission has only 15,300 Miles on it, origional. The fluid was fine earlier in the summer when I checked it, and it never leaked a drop. I NEVER pound on it. I never downshift it hard ( As in no downshifts that will throw me over 3500 RPMs, in fact, I usually will shift into nuetral and just use my brakes cause brakes are cheaper to replace than a clutch ). You oculd pretty much say my car is babied. I have NEVER, in the 3300 miles I've put on it, ground a gear, missed a shift, did anything stupid that will mess up trannys, no powershifting. The car RARELY sees abuse. What the **** could be causing this?
My clutch fluid is fine, and it doesnt seem to be leaking anything anywhere?
Old Oct 29, 2004 | 12:06 PM
Re: What the @)$(&%# is wrong with my M6 ? HELP ASAP!
Anyone ??? This is starting to drive me insane! ...
One update ... The Clutch fluid, which is Brake fluid, is a dark color instead of the typical light tinty sahde to it. Is it possible that my fluid is bad ( Possibly boiled since the line is close to the headers ? ) And thats why it started acting up out of nowhere? If the fluid was bad, wouldnt that prevent the slave cylinder from working right? Which would then make my clutch not disengage all the way, and occasionally grind and **** when I try to shift ... ??? Anyone
Old Oct 29, 2004 | 03:22 PM
crash4cyl's Avatar
sounds like the tranny is shot...it wouldn't just pop out of gear if it were the clutch. Looks like you need a new tranny, because all those noises aren't normal syncro's grinding. Good luck.
Chris
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
Aaront810
Sep 11, 2015 11:24 AM
