Question about orange thread sealer on GM parts........
Old Oct 18, 2004 | 08:38 PM
ACE1252's Avatar
I'm curious about what type of sealant that GM uses on some of it's parts. In particular, the sealant used on coolant sensors and the fittings that connect the oil pressure sensor on the back of the engine.The reason I need it is because I thought I had overtightened the oil pressure sensor(ie stripped threads). So I took the fitting that sensor connect to loose to check the threads. The threads looked great and now I can't tighten it up and have the the oil pressure sensor hole sit in the right location. So I assume that I need that sealer to seal it up and lock the fitting in place.
The only thing I can tell is that it is orange. That stuff must also serve as a type of thread locker, cause it was tough to break loose and now given the same amount of turns I used to take it loose...it will not tighten up. Anyone know anything about that orange thread sealant????
Old Oct 18, 2004 | 09:11 PM
ACE1252's Avatar
Re: Question about orange thread sealer on GM parts........
I've been doing some searching, is this what I need?
http://www.permatex.com/products/ind...read%20Sealant
Old Oct 18, 2004 | 09:14 PM
ACE1252's Avatar
This kinda looks like it.....
http://www.longlok.com/products_vibraseal.htm
Can someone confirm if this is the stuff on the threads of some GM parts?
Old Oct 18, 2004 | 10:01 PM
Dave89IROC's Avatar
vibra-seal is what comes on the threads, it looks like that permatex stuff is for the aftermarket sevicing as a vibra-seal replacement, so, get some of that permatex stuff and tell us how it works
Old Oct 18, 2004 | 10:08 PM
Spinner's Avatar
I use GM thread sealant.
Old Oct 18, 2004 | 11:18 PM
ACE1252's Avatar
Thx for the confirmation and advice on what to use guys. I got some Permatex High Performance Thread Sealant(PN#56521) on order. I'll let ya know how it works.
Feffman
Oct 9, 2015 05:42 AM
warmeck
Mar 1, 2015 08:47 PM
alex5366
Feb 17, 2015 10:43 PM
jayvar
Feb 2, 2015 10:00 PM
ChrisFrez
Nov 23, 2014 10:33 AM
