under the axle exhaust clearance
Old Oct 18, 2004 | 12:37 AM
lt4 fd's Avatar
How much room is there between the swaybar and the exhaust system by the rear axle, just trying to get an idea as to how much clearance to allow since Im taking the car to the exhaust shop for them to take a look and me to basically explain exactly what I need.
Old Oct 18, 2004 | 06:18 AM
teke184's Avatar
Re: under the axle exhaust clearance
BETWEEN the sway bar and axle
i think an 1" or 1 1/2"
i've seen several guys run duals under the axle and not have trouble with clearance in most driving situations. is that what you're planning
Old Oct 18, 2004 | 12:08 PM
Mtrhds94Z's Avatar
Do you mean 'between the axle and the panhard rod'?
Old Oct 18, 2004 | 02:31 PM
lt4 fd's Avatar
.....no guys just like it says, how much room between the sway bar and exhaust system lol, since the sway bar is the lowest hanging part that moves with the axle. Just wondering how much clearance to allow between it and the exhaust when the suspension rebounds from a hill or bump etc... Oh and yes I am planning going under the axle, gonna try to take it to a shop to have them give me a quote and just want them to know exactly whats in store so I get a very accurate quote and they know exactly what to do.
Old Oct 19, 2004 | 01:23 AM
lt4 fd's Avatar
I appologize if I came off as a jerk in that last reply, wasnt my intention just incase I did. Does anyone have any ideas that has their exhaust set up like this?
Old Oct 19, 2004 | 02:03 AM
n2oblkz
Guest
Posts: n/a
Go to LS1sounds.com and go to the page that has the picture of the exhaust. There is an F-body on there that has duals under the axle. It's not a real good picture but you get the idea.
Old Oct 19, 2004 | 12:14 PM
lt4 fd's Avatar
thank you very much
Old Oct 19, 2004 | 12:48 PM
RedLT4Mike's Avatar
Look at mine...I've had ZERO problems with clearance...
I've been jacked up, on a body lift, gone over the worst tracks in town with NO problems!
http://www.imagestation.com/mypictur...ption=100_0182
http://www.imagestation.com/mypictur...ption=100_0184
http://www.imagestation.com/mypictur...tion=duals%203
http://www.imagestation.com/mypictur...tion=duals%202
Old Oct 19, 2004 | 05:41 PM
1995greenTA's Avatar
How much did that cost you if you dont mind me asking...also what size of tips do you have, and are those 315 nittos?
Old Oct 19, 2004 | 07:13 PM
RedLT4Mike's Avatar
I took my xpipe and mufflers(moroso spiral flo's) to an a reputable local exhaust shop and had them do the work.
2.5 Aluminized Pipe + Labor = $200
I think the muffs were 100 for the pair
$60 for the tips
and 50 for the xpipe
sooo.....about $410 total
http://www.mainstreamtopics.com/memb...alsoutside.MOV
http://www.mainstreamtopics.com/memb...ualsinside.MOV
HarleyZ28
Oct 5, 2015 06:23 AM
May 21, 2015 01:04 PM
BLK1997Z28
May 7, 2015 03:01 PM
Ringmaster72
Apr 2, 2015 08:32 PM
carl.froehlich
Mar 13, 2015 12:38 AM
