285/40/17" rear tires?
Since I'm upgrading my brakes I will finally need to go to 17" wheels. I don't like the way 315/35/17's look, they just appear too wide to me and I am not sure they would fit on my '95 'vert anyway. It's never established to my complete satisfaction that there is any less clearance on a 'vert, so any experiences with this size (on a coupe or a 'vert) would be welcome. I am going back to stock ride height, BTW.
Has anyone ever used tires in this size on the rear of a 4th gen? The section width on the g-Force KDW I want to use is 11.3". This compares to 10.9" for the 275/40/17 and ~12.5" for a tire in the 315/35/17 size. The 255/50/16 I am now using has a 10" section width and there is plenty of clearance.
Thanks.
I will also post this in "LT1 Tech" and hope this isn't regarded as a sort of "cross-posting".
Rich Krause
Thanks.
Rich Krause
Re: 285/40/17" rear tires?
Rich Krause
Rich Krause
I used to run the GS offset 17x11's on the rear of my car ( a vert) and did so successfully with a solid endlink Herb Adams panhard bar. I also had A LITTLE, clearancing on the inside front of the wheel well. NO biggie. I never needed to roll the lip of the wheel well either. It never moved. I had lowered springs on the car at the time I had them on there and the ONLY time i had a clearance issue was when i had someone or two in the back and went around a corner ( not slowly).. The tires would rub then.
The tire I ran was a Sumitumo 315 though and I don't know if its cross section is as wide or wider than the KDW...
I would go for it and with a stock height you shouldn't have any issues.
Later,
STEW
Re: Re: 285/40/17" rear tires?
Originally posted by stewmeistr
Rich,
Later,
STEW
Rich,
Later,
STEW
Rich Krause
Thanks.
Rich Krause
Thanks.
Rich Krause
I believe a piece like this is the key to keeping everything in its place..
http://cgi.ebay.com/ebaymotors/ws/eB...867925695&rd=1
later.
STEW
later.
STEW
Thanks for your suggestions. I am going to get an adjustable panhard rod from Spohn with poly bushings. I'll bet those spherical rod ends are brutal
I mounted up the tires and they sure look good. It's be interesting to see how they work!
Rich Krause
Rich Krause
Rich,
Thats just what i'm trying to say. The rod isn't... I can't figure it out but it isn't even noticeable.?? I will let you centralize the rear end however which the poly won't nor will it stop the deflection of the body over the rear in a hard corner.. Its your $ and mine is only $.02
STEW
STEW
Based on the advice I recieved here I purchased some 285/40/17 tires (BFG G-force KDW) for the rear of my '95 'vert. I mounted them on my 17x9" rims and they mounted up fine even though this is 0.5" narower than recommended. Even with the car lowered I looks like they would work ok, but I am not going to use them until next season when I am back to a stock ride height. I also purchased an adjustable PHR. The stocker should have been replaced anyway and the adjustment may prove useful.
The 285 on a 9" rim fill out the wheel wells perfectly from an appearance point of view. I hope they perform as well as they look!
Thanks for your help
This board is a great clearing house for information about the F-body - may it live forever
Rich Krause
Rich Krause
Rich Krause
Rich Krause
Although, due to the wide offset of my wheels ~+44mm~ I've scrubbed the fender lip once or twice on hard bumps, but my car is pretty low as I use John Ames springs.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
carguy0119
Apr 11, 2016 11:11 PM
Moshbmx1
Jan 20, 2015 03:27 PM
