Block Casting Numbers
Old Oct 9, 2004 | 09:00 PM
pgriffith's Avatar
I have an engine here. I believe its a 454 but im not sure. Is there any way you guys can help me decode the block casting numbers?
I found 3 numbers on the block:
14015445p
E18382 or it might be E1B382
and then this one was on the front of the engine:
TQ52ITAB
Old Oct 10, 2004 | 10:48 AM
pearlpurple's Avatar
Re: Block Casting Numbers
these links should help you out a bit.
I looked the block up and it is a 1978 to 1990 454 with a 2 or 4 bolt main
http://www.mortec.com/location.htm
http://www.nastyz28.com/decode.html
http://www.67camaro.net/bynumbers/heads.htm
http://www.aacncclub.com/
Old Oct 10, 2004 | 02:19 PM
jg95z28's Avatar
T0521TAB Tonowanda built May, 21, T = Truck, AB = application
F'n1996Z28SS
Aug 23, 2023 11:19 PM
pimpss96
Feb 12, 2015 01:28 PM
ModdedNerd
Jan 29, 2015 07:23 PM
FryZss
Sep 3, 2002 03:52 PM
