Is there LT1 edit for 93's
Old Sep 29, 2004 | 02:00 PM
Finchinater's Avatar
Went to the site and only saw the earliest programs for 94's. I realize that it's speed density, but shouldn't there be apps for that also. Please help. My woman has a laptop and would like to get some logs and programming done.
Finch
Old Sep 29, 2004 | 05:49 PM
madwolf's Avatar
Re: Is there LT1 edit for 93's
www.tunercat.com
You will also need a eeprom programmer and a piggyback adapter is recommended.
www.moates.net for the other two.
Also get the SST flash chip from him while you're at it. This will save you some money and time by not having to burn and erase a new chip each time plus no need for UV eraser.
Old Sep 29, 2004 | 07:45 PM
Highlander's Avatar
Hey madwolf... is it totally impossible to have 2 flash chips on the $EE PCM? so one can switch from different programs?
Thanks
Old Sep 29, 2004 | 07:53 PM
Highlander's Avatar
I was thinking on getting the usb to aldo converter along with both cables... it would be really neat...
Old Oct 1, 2004 | 10:11 PM
Alvin@pcmforless.com's Avatar
Moates sells a new USB -> ALDL cable that can flash the 94-95;s (as you know some cheaper cables cannot)
They've worked on most labtops i've tried them on.
www.moates.net
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
Bando
Aug 2, 2002 02:18 PM
