LT1_Edit help for Air Fuel Ratio Tuning...
Old Sep 28, 2004 | 03:05 PM
BigRed1's Avatar
A very basic question with an (expectedly broad) answer... I dyno tuned the car today and need help with air fuel ratio. The car was rock steady on the AFR, usually 11.2 - 11.5 each run through the entire RPM band. I was happy to see it safe and have a decent baseline but now I'm wanting to dive into my tune a little deeper. I'm a semi-noob to LT1_Edit and have played with a few things (injector size, converter lock-up, etc) but the performance tuning was done by a friend. He knew his way around the car and the program much better than I but I moved (he hopefully still in Fl and I in Mo) and was looking to become a little smarter. Is there a simple answer on how to lean the AFR from 11.5s to 12.5s? If so or even if not, feel free to teach me about LT1_Edit and fuel tuning. Thanks!!!
Old Sep 28, 2004 | 04:04 PM
TriPinTaZ's Avatar
Re: LT1_Edit help for Air Fuel Ratio Tuning...
PE vs RPM table
Old Sep 28, 2004 | 08:22 PM
Dan K's Avatar
If you're a/f ratio is fairly linear like you say it is, leaning the car out should be fairly straightforward.
PE vs RPM table is what you want. A good rule of thumb is that for every 10 points of PE vs RPM you add or subtract, you're changing your a/f ratio approximately 1 point. So by subtracting 10 points out you should effectively lean your car to to 12.2-12.5 to 1.
Make sense?
Old Sep 29, 2004 | 09:11 AM
BigRed1's Avatar
Dan & TriPinTaz,
Thanks for your reply. PE versus RPM makes sense (I did some searching/reading as well). And the info regarding the number of approx points is just what I was looking for. I appreciate your response and hope to report back with gains.
Old Sep 29, 2004 | 11:20 AM
BigRed1's Avatar
Just to be sure (I know dumb question) but by lowering my PE vs. RPM approximately 10 POINTS, is this 1%? For example the block would have 2.0 @ whatever RPM and I should lower it to 1.0? Not -8.0 right? Or 6.6 and I should lower it to 5.6? Meaning .1 equals 1 POINT . Sorry for the Noob type question but just wanting to be sure.
Old Sep 29, 2004 | 11:09 PM
rpm4lalo's Avatar
subscribing
Old Sep 29, 2004 | 11:48 PM
shoebox's Avatar
Originally Posted by rpm4lalo
subscribing
Thanks for the update, LOL.
Old Sep 30, 2004 | 09:06 AM
BigRed1's Avatar
Agreed... Um thanks RPM. So is a point 1 whole percent or .1 of a percent? I think 10% change makes more sense for the change but just want to be sure.
Old Oct 1, 2004 | 09:20 PM
Dan K's Avatar
Example:
If you have 10 in your entire rpm range and with a wideband O2 sensor you're seeing 12:1 a/f ratio...
If you knock the pe vs rpm down to 0 for the entire range you should see approximately 13:1 a/f ratio.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
97ss1826
Mar 13, 2003 11:58 AM
Burn_Out
Aug 18, 2002 08:49 AM
