Too much play in the steering wheel
Old Sep 26, 2004 | 05:15 PM
75 outlaw LT's Avatar
On my '75 LT there is about 1-1 1/2 inches of play on the steering wheel. My father suggested a new steering box. Is there anyhting a little easier/cheaper that I could do to fix this? Or is that the ultimate solution?
Old Sep 26, 2004 | 08:11 PM
angel71rs's Avatar
Re: Too much play in the steering wheel
Check for worn components while someone works the steering wheel. Idler arm, rag coupling, etc.
You can also try adjusting the steering box, but you'd be best off taking it to a suspension shop to do it:
http://www.partsmikeparts.com/sagina...adjustment.htm
Old Sep 28, 2004 | 07:33 AM
Todd80Z28's Avatar
How's the front end alignment? Is the toe-in correct?
Old Sep 29, 2004 | 04:27 AM
Yep, just took it to Goodyear and got an alignment done, full suspension replaced with KYB shocks, and still no help. My brother-in-law (previous owner) tried to fix it by tightening the nut on the steering box and it still didnt help. My guess is the box itself is shot. So I'm gonna try and look for one at a junk yard.
Old Sep 29, 2004 | 07:10 AM
Todd80Z28's Avatar
Take a look at the rag joint on the steering shaft going into the box, first.
Old Oct 2, 2004 | 05:05 PM
69camroking's Avatar
My camaro was pretty loose in the steering dept. but replacing the ball joints and pittman/idler arm cleared it right up for me.
Old Oct 5, 2004 | 03:40 PM
JamesTKirk41's Avatar
Check out this thread from NastyZ228.com's big board.
http://www.nastyz28.com/ubb/Forum10/HTML/006036.html
Instructions on steering box adjustment.
Victor Lamb
Aug 26, 2017 02:52 PM
nikko
Apr 28, 2015 10:05 AM
Airplanedoc
Feb 1, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
