Bad roads, brutal ride...
Old Sep 17, 2004 | 07:22 PM
gt_biker13's Avatar
I realy hate the raods where i live, theres bumps and potholes everywhere. What can i do to make the ride smoother without raising/ lowering it or spending alot?
Old Sep 18, 2004 | 02:04 PM
Jabberwocky's Avatar
Re: Bad roads, brutal ride...
What tire pressure are you running right now? Try letting a couple pounds out.
Old Sep 18, 2004 | 07:24 PM
Camaro_Maniac63's Avatar
Get better shocks (preferably Bilstein HDs if you are going to stick with the stock springs).
Old Sep 20, 2004 | 10:43 AM
LT4Firehawk's Avatar
Our roads are about the worst in the country (and yes, I've driven through a good bit of the US for comparison. I've found that the SLP Bilstien Level II suspension that came on the Firehawk/SS is about the best riding f-body suspension, while still providing handling much better than stock. You can buy the springs shocks from SLP here:
http://www.slponline.com/view_product.asp?P=70002
Old Sep 20, 2004 | 04:28 PM
O-taka's Avatar
single adj Konis set to full soft are even softer than 1LE ride-wise, but the car starts wallowing on turn in, even w/ 35mm bar
Old Sep 20, 2004 | 04:31 PM
I wouldn't go with Konis if you are concerned with ride quality. I've tried both Bilsteins and Konis, and due to their design the Koni doesn't handle initial impacts as well as the Bilsteins.
rojo10956
Classic Engine Tech
Dec 13, 2021 12:17 PM
Feffman
Oct 9, 2015 05:44 AM
BLK1997Z28
May 7, 2015 03:01 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
