Bushings
Old Sep 12, 2004 | 10:59 PM
jcamaro30th's Avatar
Question Bushings
Okay guy.. i have done searches after searches, cant come up with anything helpful... so i'm asking all you for your help?????
this is what i need to replace on my car (97 30th annv. conv. z28) all the rear bushings,,,, the bushings on the LCA's (just the bushings) endlinks, and i want to go with the poly bushings...
My questions is what's the best website to get them from?????
Old Sep 13, 2004 | 01:57 PM
Ucantcme57's Avatar
Re: Bushings
go to http://www.p-s-t.com/
Look at their Poly-graphite bushings.. they don't sqeak, and are alot more rigid than reg. poly bushings they resist body roll and other deflections.. I have them and would recommend them to anybody... PST sells front end kits, rear end kits, and even single units..
Old Sep 13, 2004 | 07:42 PM
Re: Bushings
thank you very much Ucantcme57 !!!!!
Old Sep 13, 2004 | 07:56 PM
Steve in Seattle's Avatar
Re: Bushings
don't use poly in your LCA's. bad idea.
Go with QA1 rod-ends in your PHR (need to replace the whole unit, but it's failry cheap)... quiet as a mouse in daily driving.
Poly sway bar endlinks and bushings are a great idea... as is a poly trannsmission mount (although that one can be a bit noisey).
Old Feb 25, 2005 | 10:38 PM
lt4 fd's Avatar
Re: Bushings
Wait which lca's should you not use poly in because it seems to be working great in my rear lca's...? Also what part of the tie rod end has poly in it?
sleeperZ96BT
Sep 9, 2015 08:28 AM
realistyc
Jul 28, 2015 07:32 PM
96SilverRam
May 5, 2015 09:56 PM
Apr 16, 2015 09:57 AM
dbrockma
Feb 16, 2015 02:56 PM
