Vcn-1000
Old Sep 27, 2002 | 06:55 PM
Fullagar's Avatar
Vcn-1000
any one know if the Venom VCN-1000 kit comes with a built in window switch? and if not can one be hooked up to it?
Fullagar
Old Sep 28, 2002 | 06:29 AM
my96z's Avatar
I have one and I love the system, and its damn safe! You dont really need a window switch, it will come on at full throttle only so I just lift and shift. If you just so happen to miss a shift and hit the rev-limiter(I have) it will just shut the N2O off. Its the safest one out there. For around $700-ish you get the system and all of the saftey features. Comes out way cheaper than the other ones.
If you have anymore questions let me know!
Jeff
Old Sep 28, 2002 | 07:11 PM
Moore94Z's Avatar
How does the VCN-1000 add fuel? I've heard something about it using the stock O2's to do this, can anyone clear that up? Also, what jets does it come with(ie what size shot(s) can you run)?
edit-does anybody know where you can buy a Venom kit? I've never seen them for sale.
Old Oct 2, 2002 | 07:34 AM
my96z's Avatar
The Venom uses a computer to control the fuel to nitrous ratio. It uses your O2 sensor and bottle pressure to regulate the nitrous. It has wires that have 3M clips that clip onto your injector wires. It will then increase the pulse width of the injectors to add more fuel. It will not let you go lean. It uses the O2 sensor to keep the fuel/nitrous ratio in check. As soon as it sees a lean condition it will shut off the N2O. Its real safe, I know. I have hit rev-limiter a few times and it just shuts off the juice.
It comes with 70-100HP jets and more are available. Its not as exspensive as you all may think. It runs about $700. Which is cheap when you see that it has all the saftey features already built in.
It also has a little control panel that has led's on it to show you rich/lean status, and system armed status and the arming switch on it. The juice will flow when you flip the arming switch and go full throttle. Its completley computer controlled. It will also flash trouble codes when there is a problem.
You can get them from Boroperformance.com
If you have anymore questions, let me know!
Jeff
2strokefreak
Jan 9, 2006 04:11 PM
93camaroLT1
N2O Tech
Apr 24, 2005 02:02 PM
my96z
N2O Tech
Aug 13, 2002 04:13 AM
