Drop in Kpa?
Old Aug 8, 2004 | 12:20 AM
96z's Avatar
96z
Drop in Kpa?
Does does a drop in Kpa mean? For example the MAP sensor drops from 98 Kpa to 89 Kpa....?
Old Aug 8, 2004 | 09:33 AM
Dan K's Avatar
Re: Drop in Kpa?
Doesn't that mean that there is a restriction somewhere?
I'm actually not too sure, never seen it before.
Old Aug 8, 2004 | 10:51 AM
96z's Avatar
96z
Re: Drop in Kpa?
I thought it represtented a restriction also.
Old Aug 8, 2004 | 05:23 PM
joebeemish's Avatar
Re: Drop in Kpa?
My MAP kpa bounces all over the place between 25 & 100 - is this a problem?
Old Aug 11, 2004 | 08:35 AM
PoorMan's Avatar
Re: Drop in Kpa?
MAP is used to measure engine load. 100% throttle=100 MAP. Btw, MAP and vaccum are inverses so at idle a low MAP means you have good vaccum.
Old Aug 11, 2004 | 12:28 PM
joebeemish's Avatar
Re: Drop in Kpa?
My MAP is about 50 at idle. Is this good or bad or???
Old Aug 18, 2004 | 12:07 AM
cmillard's Avatar
Re: Drop in Kpa?
Given your setup that's about right for idle vacuum.
Remember pressure in the intake is limited by atmospheric pressure, which is elevation dependant. The best is 101.3 KPA at sea level. Be sure to compare MAP reading with engine off for reference.
At higher RPM's it's common for MAP to decrease (vacuum increasing) since there isn't enough time for the air to enter the cylinders. This will also show as a leveling of airflow, a decrease in torque - hence horsepower as rpm increases.
How to get more air in chamber? Hold the intake valves open for longer duration, a la bigger camshaft.
Hope this helps,
-Christian
9t4lt4z28
Oct 2, 2015 10:28 AM
kandied91z
Sep 30, 2015 11:43 PM
drt
Sep 27, 2015 04:39 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
tdigger9899
Sep 7, 2015 10:56 AM
