Temp Gauge not workin..
Old Aug 4, 2004 | 12:57 AM
Kuruption562's Avatar
my tempature gauge has been out for quite a while now. The gauge is all the way down for about the first 10 minutes of driving, then after that it slowly rises but it doesnt mark right. I dont like not knowing the temp of my car. I can feel the car getting hot but it doesnt mark correctly so i try to make all my trips 15 min or less. The mechanic said its an electrical problem, are they expensive to get fixed?
Also my coolant is real dirty, will dirty coolant cause the car to run hot? im gonna drain it, what type of coolant you guys recommend?
Old Aug 4, 2004 | 02:04 AM
Stekman's Avatar
Re: Temp Gauge not workin..
1.) Sensor
2.) The green stuff
Old Aug 4, 2004 | 02:32 AM
Which one would it be? Air Charge Tempature Sensor or Air Cleaner Tempature Sensor?
Old Aug 4, 2004 | 05:43 PM
Rice Killer87's Avatar
it could be the Coolant Temp. sensor...located between cylinders 1 and 3. nothin to do w/ air temp.
Old Aug 4, 2004 | 08:20 PM
had the coolant temp sensor changed last november, still didnt work. any other suggestions?
Old Aug 5, 2004 | 11:11 AM
hodge's Avatar
there are two coolant temp sensors. One for the computer and one for the gauge.
the one that runs the gauge is in the drivers side head between cyl 1 and 2. make sure the wire is on the end of it. it's a green wire on my 87. if it is then replace the sensor.
Hodge
Old Aug 5, 2004 | 11:23 AM
raul.garcia's Avatar
This is a single wire sensor no teflon tape, or sealer of any kind is required, because the body of the sensor is used to complete the circuit to ground.
Are you having any other electrical problems, check the ground strap connecting the driver side cylinder head to the firewall.
Old Aug 5, 2004 | 01:45 PM
Damon's Avatar
Like was said above, the sender that runs the gague is in the driver's side cylinder head under the exhaust manifold between cylinders 1&3 (front 2 cylinders). To test the gague unplug the wire from that sensor and ground it out against the engine wherever's convenient. When you ground it the gague should peg full-hot. If it does, it's not the gague or the wiring- it's the sender.
KYWes
Jun 14, 2022 06:52 AM
Henson071
Dec 30, 2015 09:55 PM
malikot02SS
Aug 15, 2015 01:11 PM
MikeWhitener
Aug 2, 2015 06:17 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
