Solid Roller Part Number Question
Old Aug 3, 2004 | 08:32 PM
smokindastangs's Avatar
I was wondering if anyone knew if a 12-225-4 (cc306 solid) and a 813-16 (solid lifters) would work on a LT1 engine. Also, Would I need an extra vacuum canister? Thanks, Jason
Old Aug 3, 2004 | 08:57 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Re: Solid Roller Part Number Question
cc306 is not a solid roller cam. its is hyd.
Old Aug 3, 2004 | 09:00 PM
well....this isn't just a regular 306. Even comp has this part number listed as a solid roller.
Old Aug 4, 2004 | 12:02 AM
Mindgame's Avatar
I assume you're talking about the S306? May want to check that one again... it's a mechanical flat tappet cam, not a roller.
-Mindgame
Old Aug 4, 2004 | 11:49 AM
Ok, well I am glad that I am aware of that...now will it work in an lt1?
Old Aug 4, 2004 | 12:45 PM
SStrokerAce's Avatar
the -4 at the end of that part number gives away the fact that it's a flat tappet cam. 813's are flat tappet lifters too, they go with the cam but not what you are looking for.
Bret
parkers Z28
Mar 11, 2016 08:14 PM
95chwagon
Jan 13, 2015 09:19 PM
FirebirdGT
Dec 13, 2014 10:25 PM
