Strange tuning problems
Old Aug 2, 2004 | 06:26 PM
chucks97ss's Avatar
Car is a 94Z28 with a fresh D1SC blower. Doing tuning on it right now, and can't get it right at all... The only thing I can get to effect my a/f is the injector sizing. Any changes in any of the other fuel tables does absolutely nothing. To get the car to run in the mid 12's a/f under wot, I had to set the injector sizing to 21 #. That in effect is causing the car to idle at 10.8:1. Above 4500 RPM the motor goes lean and detonates. It's basically doing the exact opposite of what it should be doing. The car has a brand new inline fuel pump... but possibly the intank pump is going out? It's got about 55-60 lbs of fuel pressure at wot. Any thoughts would be appreciated...
Old Aug 2, 2004 | 08:22 PM
SABLT194's Avatar
Re: Strange tuning problems
Are you working with the MAF calibration table or the PE table or both?
Steve
Old Aug 2, 2004 | 09:36 PM
chucks97ss's Avatar
Steve
PE Table. MAF table doesn't effect WOT on OBD1 as far as I know...
Chuck
Old Aug 2, 2004 | 10:39 PM
turbo_Z's Avatar
So you are saying that adjusting the PE tables isnt effecting the AFR at WOT? Maybe you arent adjusting them out far enough or in the wrong direction?? I have this excel program that calculates the PE values based on your current PE values and the AFR reading you get using at wideband on the dyno. I havent had a chance to put it to use just yet but I believe it should work great. I found this program on a guys web page.. his name on cz28 is cmillard and I think the link to his site is in his sig so you could try searching for his name.
Old Aug 3, 2004 | 05:21 AM
SABLT194's Avatar
MAF will certainly effect fueling at WOT. You must be in Closed Loop for the PE table to come into play however. Are you running an open loop program?
Old Aug 3, 2004 | 09:44 AM
chucks97ss's Avatar
Basically I zero'd out the PE table to start from scratch. I went as high as 5.5 in the 4000 rpm and above range, and that did absolutely nothing. So unless 5.5 is a very small number on LT1 edit, there is something else causing this thing to do what it's doing. I'm still leaning towards fuel pump..
Thanks,
Chuck
Old Aug 3, 2004 | 09:48 AM
chucks97ss's Avatar
Not unless somebody before me tuned it that way. But I doubt it.
Chuck
Old Aug 3, 2004 | 12:24 PM
LWillmann's Avatar
PE tables are %change to fuel vs temp and RPM... so assuming you're working the PE vs RPM table as most of us do, you're only making an adjustment of x% above base fueling.
So if the car is lean before going into PE it will continue to be lean and require larger numbers in the PE table to compensate.
For example: my stock table had values as high as 9.8 in the PE vs RPM table, well after installing my headers, the car was lean and adding fuel prior to WOT. I mistakenly locked the BLMs and added 3 more to the PE table making it a total of 12.8 and it made up for the lean condition, I would have had to add even more to get the ratio lower to make up for the increased chance of detonation with a blower.
Now, I'm tuning the MAF table by logging, and making adjustments to the MAF table based on the average fuel trims for each step in the MAF table. That should get my Ltrims (BLMs) close to 0 (128) and then let me reliably tune the PE vs RPM table.
I'd say that getting the Injector constant set right, and adjusting the MAF table will get you MUCH closer to where you want to be at WOT. Shoot for the tune to be a tad rich before going WOT, that way you're better off during WOT runs, and then tune that PE table. Oh, and make sure you're BLMs are not locked during WOT.
Just my opinion here, but this approach seems to be working for me...
Old Aug 4, 2004 | 08:18 AM
bunker's Avatar
I think at WOT before closed loop the PCM might be looking at the VE tables what do you think? cuz I know in open loop the PE table is ignored now LOL, I don't think tunning the MAF table will be any more accurate then the PE table unless there is a sertain area that you can't alter with the PE table then use the MAF to alter that A/F like say between the PE rpms.
Matt.
Old Aug 4, 2004 | 12:27 PM
chucks97ss's Avatar
Matt.
Just to see if it did anything, I leaned the MAF table out by 25% across the board, and it did effect my a/f by about 2 points in closed loop. But open loop it still leaned way out, even with PE values as high as 21.
Chuck
Old Aug 4, 2004 | 05:42 PM
SABLT194's Avatar
Oops, I just saw that you have a blower. Are you pegging the MAF?? If so, your only solution is to put big, big numbers in the PE table or use an FMU (boost referenced fuel pressure regulator) to add extra fuel.
Steve
Old Aug 4, 2004 | 07:29 PM
chucks97ss's Avatar
Steve
It's not responding to PE table changes, unless I need to go even bigger than 21... And it's got an FMU that's adding over 15 lbs of fuel pressure. Goes from 45-62 under wot. Something has got to be messed up with this car....
Chuck
Old Aug 5, 2004 | 05:35 AM
SABLT194's Avatar
Can you post some MAF vs RPM readings on one of your Dyno pulls. Kinda sounds like your MAF might be hosed up. Also make sure that you are really entering PE mode, theres a PE enable vs TPS table (this one's a long shot). Another question, If your injector constant is set to correct #, how are your BLM's at idle and at various cells during cruise? we might be able to narrow down some WOT problems be evaluating part throttle characteristics. My tuning philosophy is:
1) Do Idle 1st
2) Then spend most of my time on driveability, part throttle tuning, and BLM's
3) Only head to the dyno when step 1 and 2 are hunky dory
Steve
Old Aug 5, 2004 | 09:44 AM
chucks97ss's Avatar
1) Do Idle 1st
Steve
Well I own 2 dyno's, so heading to the dyno is only 50 feet away for me
Chuck
Old Aug 5, 2004 | 06:26 PM
SABLT194's Avatar
If I lived in Houston I would become your very best friend in the whole world!
