Full port AI + 8lb Procharger
Old Aug 1, 2004 | 09:49 AM
ProchargedZ's Avatar
I have a 96Z stock motor with 8# procharger and most bolt ons including Hooker long tubes and off road Y. Best Dyno was at 406 hp 418 ftlbs before the LT's and Y and a few other things.
I just ordered from AI:
LT1 Full Port Competition Package with 977 Spring & 730 Titanium Retainer Upgrades
INCLUDES LISTED COMPONENTS & SERVICES:
Ferrea 6000 Series Competition Valves 2.00I/1.60E with Teflon Seals
CompCams 977 Valve Springs
CompCams 4771 Hardened Steel Spring Locator
CompCams 730 Titanium 10degl Retainer
CompCams 613 Hardened Steel Super Lock 10deg
Port & Polish Intake & Exhaust Runners
Unshroud, Reconture, & Polish Chambers
Proprietary Competition 45deg Valve Job w/Valves Lapped & Backcut
Milled to Insure Flatness & Achieve Desired Chamber Volume
Full Documentation Including Flowsheet & Assembly Specifications
Extreme Performance Hydraulic Roller Kit:
INCLUDES LISTED COMPONENTS:
CC875 Pro-Magnum Roller Lifter
CC1117 Hi-Tech 15-5 PH Stainless Rocker
CC4501 High Energy 7/16" Rocker Studs
CC4810 Hardened 4140 Steel Flat Guide Plate
Ai One Piece Hardened 4130 Chromemolly Racing Pushrod
Install K-Line Bronze Guide Liners and Finish Hone to Size
CompCams Custom Hyd Roller Spec'ed For Blower Applications
Labor & Parts To Replace Exhaust Valve Seats for 1.600dia Valve
..... Along with a 58mm AS&M TB. I still plan on doing a ported intake and need a few other things like the extreme timing chain, LT4 knock Module, PCM tuning, and injectors.
My question is how big should I go on the injectors? People are getting pretty close to 400rwhp with AI's Heads, and Cam according to their website dyno postings. I gained around 130 rwhp from the blower should I look for numbers over 530 because of a better valvetrain and better flowing heads, making the boost more efficient?
I also bought Racetronix in-tank and harness kit. That along with the external fuel pump that came with the procharger and the FMU (which I would like to get rid of) So with all that, what size injectors should I buy?
Old Aug 1, 2004 | 10:02 AM
SMOKNZ's Avatar
Re: Full port AI + 8lb Procharger
$hitcan the inline pump and only run the Intank. The inline will only be a restriction. You can run 42# injectors up in the neighborhood of 500 RWHP, and that Racetronix kit will support it! Just as a word of advice, those heads will probably increase your non-boost friendly compression ratio becaused they are going to be milled for flatness. Keeping detonation away from your combo is going to require something drastic.... methanol maybe?? Wouldn't be a bad decision if you want the stock motor to live a little longer.
Bill
Old Aug 1, 2004 | 10:10 AM
The inline will be a restriction? Okay, well I guess that is one less thing I have to worry about breaking. So 42lbs and just the racetronix kit should deliver sufficient fuel?
As far as the compression ratio, I asked for 64cc combustion chambers to help alievate some of the increase for the milling.
Hopefully that works out. I have been looking at www.alkycontrol.com though.
Old Aug 1, 2004 | 03:52 PM
SMOKNZ's Avatar
See the Hp and TQ in my sig with my old turbo kit. That was done on stock lines, rails, and regulator with 42#injectors and a dual Racetronix pump kit. The single alone will support 550 RWHP and if you need more add a boost-a-pump. My injectors were near maxed though.
Old Aug 2, 2004 | 09:48 AM
Blownbird355's Avatar
Get as large of injector you can to keep from upgrading again. 48's or 50's and someone is now making 60 low impeadance but I dont know who or how much...
Old Aug 2, 2004 | 10:07 AM
IDOXLR8's Avatar
If you are thinking that you will make 530 rwhp than I would recommend going with Siemans 57lb high impedance injectors.
Old Aug 2, 2004 | 04:38 PM
That is just a guess becuase of the numbers that are posted on AI's website. People are getting close to or just over 400 rwhp with similar packages on stock motors with exhaust and minor bolt ons.
My blower added 127 rwhp on a before/after dyno. 57's huh? Will that make me run rich since I only need that much fuel when I am at WOT?
Old Aug 2, 2004 | 10:07 PM
TimbrSS's Avatar
No, when you tell the computer that you are running 57's, it will compensate.
Old Aug 3, 2004 | 06:10 AM
IDOXLR8's Avatar
I agree.
Also regardless of what injector you go with I would highly a good intank fuel pump. You may want to take a look at the one that is offered by Racetronix.
Old Aug 3, 2004 | 08:49 AM
I agree.
Thanks guys, and I actually already have the Racetronix kit. Just haven't put it in yet.
So is it low or high impedence that I need?
Old Aug 3, 2004 | 08:59 AM
IDOXLR8's Avatar
You will need a high impedance injector unless you decide to run an Acceleronic convertor box.
Old Aug 3, 2004 | 04:05 PM
Sorry I meant High Impeadance
Old Aug 4, 2004 | 12:57 AM
Racetronix's Avatar
Wow, this is the first thread I have read in a long time where all the advise is correct!
Carry on gurus...
Old Aug 4, 2004 | 02:56 AM
GhostZ's Avatar
Carry on gurus...
Actually I would suggest you ditch the entire project and swap in an SR20DET.
Yeah I had to be the one to ruin the streak.
Old Aug 4, 2004 | 03:08 AM
Racetronix's Avatar
Trying to throw a wrench in there huh?
