355 or 383 for a FI setup?
Old Aug 1, 2004 | 09:35 AM
TransAmTONY's Avatar
Besides the obvious differences of having more CI and low end torque of a 383... Is there anything advantageous of a 355 over a 383? Since the 383 is stroked its piston speed is higher which means more wear on the rings correct? Are there any clearencing involved in a 383 setup that would cost more for labor? All thoughts appreciated...
-Tony
AlAsad Iraq
Old Aug 1, 2004 | 09:45 AM
Mystic95Z's Avatar
Re: 355 or 383 for a FI setup?
The 383 will require the block to be clearanced, so yes there will be more labor. Also given all things equal except the stroke diff between the 355 & 383, the compression will be higher on the 383.
I'm going to go with a 355 for my buildup.
-Tony
Old Aug 1, 2004 | 09:46 AM
2MCHPSI's Avatar
Like the old saying goes, there is no replacement for displacement
Old Aug 1, 2004 | 10:21 AM
97WS6SCharged's Avatar
You're saying that in the wrong forum.
Old Aug 1, 2004 | 11:39 AM
MEAN LT1's Avatar
Sure there is, its called more BOOST!
Old Aug 1, 2004 | 12:40 PM
1BadAzzGT's Avatar
Thumbs up Re: 355 or 383 for a FI setup?
You know this. If anyone has little displacement, it's me and I'm making decent #'s so far with my first round of tuning. Once fuel system gets straightened out car will be re-tuned.
Old Aug 1, 2004 | 03:54 PM
Roadie's Avatar
Yeah. All the turbo honda guys know this...
boost =
stroker + boost =
stroker + boost + nitrous =
It's your choice.
Old Aug 1, 2004 | 09:23 PM
MEAN LT1's Avatar
It's your choice.
Thats what Im talking about.
Old Aug 2, 2004 | 12:44 AM
So there are some clearancing involved in a 383... SO if i had a professional build a 383 for a LT1 versus a 355, what would the cost differences be? Would it be that marginal to opt for a 355 and compensate with 1-2lbs more boost?
Old Aug 2, 2004 | 04:08 AM
rskrause's Avatar
There is no significant difference in cost (assuming a new rotating assy in both cases) between a 355 and a 383 build up. Maybe $100 in addtional work on the block.
Rich Krause
Old Aug 2, 2004 | 09:47 AM
donot_4get's Avatar
I know this question is geting of the topic a little... but do you always need a new oilpan to clear the crank on a 383 built-up?
thanks!
leo
Old Aug 2, 2004 | 09:49 AM
rskrause's Avatar
thanks!
leo
No. Most setups use the stock oilpan.
Rich
Old Aug 3, 2004 | 07:30 AM
2MCHPSI's Avatar
Stock pan that has been modified..AKA beat the living F%CK out of it with a hammer j/k
Depending on what rotating assembly you use will decide on how well the stock pan fits.. Sometimes no clearancing at all is needed.. Other times you need to just ta pthe pan here and there
Old Aug 3, 2004 | 08:05 AM
donot_4get's Avatar
thanks guys I guess if it doesn't fit, I'll use my favorite two tools... Brute force and ingnorance
leo
Old Aug 4, 2004 | 11:55 AM
davepl's Avatar
My 396 didn't clean my -Canton- pan and we had to dimple it.
If I had it to do all over again, I'd stick with a 355 and spend the extra money elsewhere.
In theory its not that much more money, but its like anything else: sticking with the more common parts gives you better selection and lower price points.
