Weld Wheel clearance
Old Sep 26, 2002 | 11:40 AM
Grover's Avatar
Question Weld Wheel clearance
Any of you guys running Weld skinnies (15x3.5) on the front? If so do you have any clearance issues, such as do you have to run a spacer on the front?
I am thinking of changing to the LS1 front brakes and was wondering if I would still have to use the spacers on the front.
Old Sep 26, 2002 | 09:33 PM
BISHOP's Avatar
Yup you have to use a 5/16" spacer.
Old Apr 24, 2004 | 10:48 PM
96speed's Avatar
I am not using spacers, although, I did grind the the brake calipers quite a bit (LS1 convert).
You will still need to grind the calipers even with the 5/16" spacers.
Ryan
Old Apr 25, 2004 | 02:06 AM
94ZRiCeKiLr's Avatar
Ryan
not in the front.....they will work with no grinding with a spacer only.
Old Apr 25, 2004 | 06:08 PM
bski224's Avatar
i have LT1 brakes and didnt use a spacer (didnt want to use one) it makes the wheels stick out to far for my taste gives it the ghetto look a bit. Just my HO. Just did a little grinding and i was fine.
Old Apr 25, 2004 | 09:51 PM
96speed's Avatar
My friend had to grind (using spacers) on his '02 Z28.
Ryan
Old Apr 26, 2004 | 12:08 AM
Ryan
thats weird....i can't imagine why that would be different on a car to car basis. i'm not calling BS or anything but i wonder why the hell it would be different???
Old Apr 26, 2004 | 01:26 AM
AL SS590 M6's Avatar
It can depend on how new or old your brake pads are. The thickness of the pads will determine how far the caliper sits out.
Old Apr 26, 2004 | 01:27 PM
Y2K2Sierra's Avatar
Ryan
That would be me. Yes, I did have to grind a little off, nothing ridiculous, but still had to grind even with the spacer. I had heard that you could fit them without grinding with the spacers and I decided to try it. I have a couple scratches in the rear of my wheels to prove that they rubbed.
Chris
Old Apr 26, 2004 | 03:37 PM
o ok...i never even thought of that.
Fastbird93
Apr 9, 2016 07:01 PM
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
nikolt1
Feb 27, 2015 09:10 PM
squarehead
Nov 21, 2014 08:02 PM
