Spark, but no fuel or RPM after FAST install
Old Jul 26, 2004 | 08:47 PM
chevyguy3's Avatar
was wondering if anybody here might have any ideas as to what my problem might be. installed the FAST ECU on my car yesterday with a fast track harness to splice into the stock PCM harness. after the install the car wont start, and the c-com dashboard is showing 0 rpm and 0 injector pulsewidth when cranking. there is spark at the coils however which confuses me even more. any ideas? i looked over it again and all my wiring appears to be correct according to the fast track harness instructions
Old Jul 30, 2004 | 03:44 PM
kevin97z28's Avatar
Re: Spark, but no fuel or RPM after FAST install
Chevyguy, I would recommend to double check your Fast Track adapter harness. Check to see if any traces are burnt and open on the adapter boards themselves. What is your part # of the ECU??
30-1x6010 or 30-1x3010??
Kevin
Old Jul 30, 2004 | 03:47 PM
chevyguy3's Avatar
thanks for the suggestion, ill look at that. i dont think the problem has to do with the FAST anymore though. i tried going back to the stock PCM and the car still wont run. just made a ton of changes at once on the car so ive got a bit of digging to do to figure out what i messed up. so far all the wiring i have checked has been ok
maybe2fast
Feb 5, 2015 05:14 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
birdblack
Dec 30, 2014 06:59 PM
hotrodyou1
Dec 20, 2014 10:05 PM
