Rear LT1 and LS1 brakes the same?
Old Jul 25, 2004 | 10:40 PM
YZF/LS1 Freak's Avatar
Are these rotors any good?
I found this on e-bay, http://cgi.ebay.com/ebaymotors/ws/eB...category=33564
I am about to go to LS1's in the front and for that much would just sell teh rears to an LS1 owner, do you think they are any good? are the power slots any stronger?
Whats better curve slot or straight?
Old Jul 27, 2004 | 03:10 PM
Ls1smlblck's Avatar
Re: Rear LT1 and LS1 brakes the same?
Well you have 2 questions here, you asked it 93-97 and 98-02 have the same rear brakes. Then are the 98-02 slotted rotors good.
93-97 rear disk are not the same as 98-02. 93-97 use a drum type E-brake in the rotor and also different caliper and mounting brackets. Brakes parts will not interchange. But you can switch out the whole rear system.
The 98-02 slotted rotors are good, the slots help expel gas pressure under hard braking, which will provide more contact between the rotor and pad.
ddr698
Jan 9, 2015 10:05 AM
Jazsun
Dec 29, 2014 12:14 PM
vals95z
Mar 18, 2003 03:45 PM
