My alky injection
Old Jul 24, 2004 | 05:55 PM
Alvin@pcmforless.com's Avatar
My alky injection
http://community.webshots.com/album/166827612lLUjaF
The two dials in the map poket are for spark retard and the other controls the pump speed via PWM.
The green light near the shifter is to let me know the system is armed and the red light near the boost gauge tells me the pump is ON.
Old Jul 24, 2004 | 08:50 PM
MEAN LT1's Avatar
Re: My alky injection
Looks good man, where did you plum the nozzles?.
Old Jul 24, 2004 | 09:07 PM
just into the intake right before the throttle body.
The car IS MEAN! with .5 degrees/pound and alcohol
Old Jul 25, 2004 | 11:19 PM
The PWM controller is one I bought off ebay, the guy had a bunch of them and they only cost $33 bucks.. I don't think i could have made something that looked that nice for the price.
The PWM is controlled by a standard 10K pot, which so happens to be the same as a MSD BTM box which i happen to have 2 contollers for.
The activation is from a TPS switch set to come on with anything above 33% throttle (right at 4psi no matter the occasion or RPM, this is a roots blower car) You could always use a hobbs switch to activate it.
In the near future I plan on using a pressure transducer ($17) to control a progressive amount and a darlington switch to control soliniod so that the alky is delievered linear with fuel.
Its never made much sence to spray the same amount of alky at 8 pounds @ 3000 as you do at 6000rpm , With this setup I can cram more alky in up top without sacraficeing lower rpm.
I've got a simple 0-5v comparator too i can use with a MAF, MAP, or TPS signal.. it only cost me about $5 to build
drt
Sep 27, 2015 04:39 PM
Henson071
Sep 18, 2015 04:01 PM
Slayer
Aug 17, 2015 03:55 PM
Henson071
Aug 4, 2015 09:32 AM
RX Speed Works
Jul 24, 2015 02:25 PM
