What are the size differences between 94 Salad Shooters and 97 Z28 rims?
Old Jul 22, 2004 | 12:58 PM
v6maro's Avatar
Is the width the same or is it different?
thanks
-Steve
Old Jul 22, 2004 | 01:14 PM
PaulN64's Avatar
Re: What are the size differences between 94 Salad Shooters and 97 Z28 rims?
they are both the same size, just diffrent styles
Old Jul 22, 2004 | 04:40 PM
v6maro's Avatar
where can I confirm this?
Old Jul 22, 2004 | 08:11 PM
All the V8 wheels, other than WS6 and SS wheels are 16x8" with a 55mm offset. The WS6 and SS wheels are 17x9" with a 55mm offset. They all have the same 5 x 4.75" (120.65mm) bolt pattern. Not all wheels have the same inside diameter for the portion of the wheel that slips over the axle "hub". Up to approx 1996, the rear hubs are approx. 0.03" larger than the front hubs, so the wheels match the larger rear hubs. From approx 1997 and newer, all hubs are the same, front and rear, so all the wheels match the smaller diameter of the pre-1996 cars, requiring the inside diameter of the 1997 and newer wheels to be sanded lightly to fit over the 1996 and earlier rear hubs.
Not sure how to convince you if you don't believe the answer.
HectorM52
Jul 30, 2017 11:46 AM
Kato
Jan 26, 2015 09:21 PM
siguy
Nov 27, 2014 10:07 AM
