holley people
Old Jul 20, 2004 | 10:20 PM
1984camaroz28's Avatar
holley people
OK i just ran all my new steel braided lines and i came down to this question. I use to run 1 line off the regulator thto the carb with one of thoes summit metal lines the Y's it. MY friend was telling me that it whould be beter to run 2 lines 1 from each side of the regulator into the car. Is this true or is he full of ****
Old Jul 20, 2004 | 11:06 PM
Stephen 87 IROC's Avatar
Re: holley people
For normal street use and an engine that makes less than 500 hp, what you did is fine.
Old Jul 20, 2004 | 11:12 PM
Re: holley people
alright so i should deff go with the dual line setup. my motor makes more then 500hp atleast on the engine dyno it does
Old Jul 21, 2004 | 01:25 PM
SS MPSTR's Avatar
Re: holley people
I did this exact set-up on my 496 BBC project. It makes a bit more than 500 hp.
Old Jul 21, 2004 | 07:55 PM
Re: holley people
It all depends on the fuel demands of the carb and engine. Normally it's only a 5/16" or 3/8" fuel line. I run 1/2" line to each float bowl of my carb. I have 5/8" fuel line from the fuel cell to the regulator.
Old Jul 22, 2004 | 09:07 AM
Re: holley people
But can you compare the fuel volume flow of an alcohol motor to a gasoline setup?
RX Speed Works
Oct 1, 2015 10:19 PM
Beave2780
Sep 23, 2015 12:37 PM
95craz28
11
Sep 12, 2015 07:47 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
