Car is having trouble starting and squeeking?
Old Jul 19, 2004 | 04:29 PM
Pabz2k1's Avatar
When I turn the key and have the clutch in the car doesn't start at all. I mean it does absolutely nothing. Like it feels I never turned the key at all. It takes like 2 or 3 turns at the key for it to finally start up. And this problem only arrises maybe one or two days a month. Also when I'm driving I can hear a squeeking coming from the back driver side somewhere but I have no idea where it is, I'm almost positive that it's coming from the inside of the car. If anyone else is experiencing these problems or has solutions to these problems then let me know. Thanks.
Old Jul 20, 2004 | 04:36 PM
JMiller's Avatar
Re: Car is having trouble starting and squeeking?
security light on?
Old Jul 20, 2004 | 07:10 PM
Pabz2k1's Avatar
Nope
Old Jul 27, 2004 | 06:03 AM
user name's Avatar
clutch safety switch? when it happens, try and find it and push the button in. or use a DMM and check for continuity when the button is pressed. if you dont even have juice to the input on the switch, check the ignition switch for continuity in the start position.
my two cents. good luck.
Old Jul 28, 2004 | 03:40 PM
gamer885's Avatar
On problem i have seen with cars not being about to start is the batter terminal connectors being all corroded up. Check your battery and your terminal hook ups.
Old Jul 28, 2004 | 07:49 PM
Pabz2k1's Avatar
Checked the battery and the terminal hook ups. And they all check out ok
Old Jul 28, 2004 | 08:49 PM
user name's Avatar
did you happen to check the ignition interlock stuff yet?
Old Jul 28, 2004 | 09:03 PM
Pabz2k1's Avatar
yeah that checked out OK to
Noenav
Mar 1, 2019 07:38 AM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
slothgrant
Aug 22, 2002 03:01 PM
