Anyone in Oregon want to meet up and tell me what the hell's wrong with my clutch?
Old Jul 16, 2004 | 12:17 AM
LT1RX7's Avatar
I just installed a brand new Spec stage 3 carbon and now it seems like my whole rear end is going to pop out. The flywheel has been resurfaced and I tightened all the bolts to spec using a star patteren. I need someone to tell me if this normal clutch chatter. I've posted on many forums and all say this teeth crunching chatter is normal. I just need someone with some experience with clutches to drive my car.
I've just installed the twin turbo with all the piping and FMIC but it kind of sucks when I take off from a red and it sounds like I have a loose truck bed attched
I live in Salem BTW
Old Jul 16, 2004 | 12:20 AM
93formula's Avatar
sounds like chatter what gears do you have out back?
theres two versions of the spec 3, one chatters a lot more then the other.
Old Jul 16, 2004 | 12:55 AM
LT1RX7's Avatar
This is an RX7 BTW with an LT1. The gears are stock 410's.
The chatter is so bad, when I down shift to go into a turn it feels like the rear tires are hopping around. I just really need someone to test drive this, I know it's not normal and it's hard to try to explain yourself over the internet. It's just horrible!!
Old Jul 16, 2004 | 01:01 AM
93formula's Avatar
with 410s the chatter shouldnt be that bad, some one will have to test drive it, could it be a suspension issue?
Old Jul 16, 2004 | 01:37 AM
bunker's Avatar
mine was pretty bad when she was new, even when I would down shift, if I didn't pop the clutch out real fast the rear would chatter, now I still get some chatter in reverse & if I'm half a sleep & want to take off up a hill on a hot day when the brain aint working then there will be a bit there.
Again, when she was new it was quite a bit worse, mostly in reverse & if I'm trying move while turning from a stop.
Matt.
Old Jul 16, 2004 | 04:35 AM
LT1RX7's Avatar
how long did it last? I'm on 100 miles and it has either gotten worst or it's the same
Old Jul 16, 2004 | 09:36 AM
Muskys SS's Avatar
It will take about 600km to really break in. I just broke mine in and it is a lot better now.
Old Jul 17, 2004 | 01:27 AM
GreenZ28in503's Avatar
LOL I just got back from Salem tonight....was down there working today.
sherwinZ28
Jun 6, 2015 08:48 PM
meissen
Jun 1, 2015 07:59 AM
timmy39120
May 2, 2015 05:12 PM
HectorM52
Jan 30, 2015 11:08 PM
njspder
Middle Atlantic
Jan 8, 2015 11:13 AM
