which year of 400 small blocks are better?
Old Sep 25, 2002 | 09:45 AM
Brew8194's Avatar
Question which year of 400 small blocks are better?
I am trying to figure out which year or maybe which is better between a 400 small block with a 2 or a 4 bolt main. I would like to know which is generally a stronger motor based on opinions.
Old Sep 25, 2002 | 11:29 AM
ahotrod79's Avatar
Go with the two bolt. And the best 400 block to use is the one that has a casting number that ends with 509. The two bolt 509 casting blocks were used from 74-80. You can also find some 2 bolt main blocks in the 70-73 year range, but they are not 509s.
Old Sep 25, 2002 | 12:23 PM
BamaZ28's Avatar
The rarest and most sought after 400 2 bolt main is a 1970! It is told to be the strongest block ever produced by chevy, due to the metal combo used. If you find a 1970 plus or minus a year, 400 or 350 don't pass it up!!!!
Old Sep 25, 2002 | 02:27 PM
Brew8194's Avatar
Question difference in 2 bolt &4 bolt
which block would be stronger and why?
bolt wise
Old Sep 26, 2002 | 03:55 AM
TAYLORMADE's Avatar
Use a 509 block with 2 bolts and install splayed caps. A 400 block has a real bad tendency to split between the mains and the cam bore. This is on 600+ hp engines used in endurance racing I.E. autocross, circle track, and etc. By the time you machine the block and install caps it usually isn't much more to use an aftermarket block like the motown, little m, or bowtie sportmans.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Collector Car
Jan 5, 2015 10:58 AM
Collector Car
Dec 17, 2014 01:12 PM
