Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
which car is faster?
Old Jul 13, 2004 | 10:16 PM
lovescamaros25's Avatar
whats faster in the 1/4 mile?A 2002 camaro ss or a 2003 mach 1 mustang.
Old Jul 13, 2004 | 10:35 PM
John1975's Avatar
The ss, but anything can happen at the track.
Old Jul 13, 2004 | 11:49 PM
bombd84's Avatar
last time I went to the track there was a stock mach 1 there running 14.0-14.3
It was 90* and 80* humidity.
Old Jul 14, 2004 | 09:36 AM
LT1ponykilla's Avatar
The 02 SS would be faster. Especially on the street.
Old Jul 14, 2004 | 11:46 AM
Antz97ZNJ's Avatar
The LS1 will normally trap more but there almost identical in the 1/4 mile
Old Jul 14, 2004 | 01:56 PM
TRICK95's Avatar
Assuming it was an actual Mach I, it should be close, but once again, ya never know. They run pretty good from the factory. And I believe they're lighter than the fbody as well.
Old Jul 14, 2004 | 07:27 PM
Steve Y's Avatar
The SS has a slight advantage, on the order of 2-3 carlengths in the 1/4 mile everything else being equal.
Old Jul 14, 2004 | 08:18 PM
ULTIMTEORANGESS's Avatar
m6 ls1 is faster.
until i see some conclusive proof im not sold on mach 1s hitting 12s STOCK.
if you have any please show me.
Old Jul 14, 2004 | 08:41 PM
Steve Y's Avatar
Originally posted by ULTIMTEORANGESS
m6 ls1 is faster.
Exactly. Fastest stock Mach 1 by Evan Smith was a 13.1x at 105ish. He ran a 12.89 at 108ish in a bone stock LS1. It took Paul Svinicki DRs to get a very high 12 out of an otherwise stock Mach 1.
Old Jul 14, 2004 | 08:44 PM
Talking
careful steve.you might cause an uproar.
Old Jul 14, 2004 | 08:45 PM
stereomandan's Avatar
That's pretty dang impressive for either car.
I agree that the LS1 has the slight advantage, although 108 mph trap vs 105 trap is a little more than a slight advantage.
Dan
Old Jul 14, 2004 | 09:10 PM
Steve Y's Avatar
Dan
Yes from high speeds the power and aerodynamics of the Camaro really shine. The Mach's gearing helps it in the lower speeds.
Old Jul 14, 2004 | 09:12 PM
Steve Y's Avatar
Oh well, I can't help it if people can't handle the truth.
Old Jul 15, 2004 | 12:05 AM
Garbage's Avatar
In the 1/4 they seem to be about even. LS1s and mach1s can both run low 13s. Its a drivers race. Why dont you ask this question on mach-1.org so you can get the other sides opinions. I bet every other post will be
mach1
mach1
mach1
Old Jul 15, 2004 | 01:54 AM
97bowtie's Avatar
mach1
mach1
mach1
Except the answers he got here are correct.
