will i need bigger injectors?
Old Jun 30, 2004 | 02:28 PM
gunter96ws6's Avatar
im currently running a cc306 with stock injectors, if i decide to spray a 100 shot would it be a good idea to get bigger injectors? if so how big, thanks~gunter
Old Jun 30, 2004 | 02:41 PM
ford's Avatar
Depends on the kit.
Wet kit id say no, you'll be fine.
But with a dry kit, id say yes. You will be very close to reaching their limits.
Someone correct me but i believe the stock injectors are only good for 400rwhp or so?
Old Jun 30, 2004 | 02:50 PM
LPEdave's Avatar
Yep that's correct. Not only that, but stock injectors have a tendency to lock up at the high pressure used on dry kits.
Dave
Old Jun 30, 2004 | 02:52 PM
ford's Avatar
Dave
good point, plus most aftermarket injectors lock in the open postition instead of closed, incase they do lock up.
Old Jun 30, 2004 | 03:16 PM
ill probley do a dry(100 shot) what size injectors should, i get?~gunter
Old Jun 30, 2004 | 03:38 PM
ford's Avatar
whatever your wallet can afford
Old Jun 30, 2004 | 05:16 PM
what would be a good size that wouldnt max out and wouldnt be over kill?~gunter
Old Jul 1, 2004 | 10:36 PM
anyone?
Old Jul 2, 2004 | 09:17 AM
ford's Avatar
38lb/hr?
even bigger wouldnt hurt, like i said whatever your wallet can handle
Old Jul 2, 2004 | 12:00 PM
Even with a dry kit, you don't necessarily need larger injectors. The typical dry kit, and specifically the NOS 5176 LT1 kit, increases injector flow by increasing the fuel pressure when you spray. Hence, you still size your injectors for the non-N2O case. As noted in a couple of the posts above, you will still need new injectors, because the stock RP injectors don't like 80psi.
In the NOS 5177 dry kit for the LS1, you may need larger injectors, since that kit simply sprays through the MAF to get the extra fuel.
Old Jul 2, 2004 | 12:16 PM
i was waiting on you to chime in fred, you know you $h!t when it comes to nitrous, thanks~gunter
Old Jul 2, 2004 | 03:25 PM
DrewHMS97SS's Avatar
with the cost of kits, i dont see the advantage to running dry. why not run wet and not have to worry. you can get some steals from racetronix or combination motorsports for injectors as well.
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
95craz28
11
Sep 12, 2015 07:47 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
