Questions about gear installation
Old Jun 28, 2004 | 07:12 AM
orbitalshock2k's Avatar
Just need some general info.
How long does the install take?
What tools are required?
How much am I looking to spend total on this?
Anyone have any sites or anything that tell you how to do it, please share. Thanks
Old Jun 28, 2004 | 12:03 PM
IDOXLR8's Avatar
Installing a rearend gear is something I would not consider tackling unless you have done one before or are getting help from someone who has. The reason I do not recommend doing it is because if it is not done right your gears will whine but most importantly the longetivity of your gears will be affected greatly.
Timing can take anywhere from a few hours to 10 hours. You will the following:
Torque Wrench
Magnet
Indicator
Bearing Puller
Gear oil and additive
Shims
Bearing kit
Ring and Pinion.
Old Jun 28, 2004 | 12:59 PM
MEAN LT1's Avatar
Agreed......Gear installs arent fun.
Old Jun 28, 2004 | 01:13 PM
ArizonaZ's Avatar
Thumbs up
i'm doing mine right now as we speak, and its not that bad at all. The biggest problem i've run into was having to wait to get the pinion re-shimed since all the shops in my town were closed for the weekend. As long as you are patient, and somewhat automotively inclined, it definately do able.
After all, its a learning experience at the same time, and by doing this myself, I've learned everything i wanted to know about my rear end.
And no, nobody who had done one previously was helping, just two other friends as curious as myself.
Old Jun 28, 2004 | 07:02 PM
Thanks a lot, my car has no pickup in higher gears. I was just thinking about this post. I had it in 3rd going 40, went about 75% throttle for a second, nothing.
ChrisFrez
Jan 11, 2015 03:47 PM
ChrisFrez
Jan 4, 2015 08:43 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
Noenav
Dec 6, 2014 07:35 PM
